Clears all packet and byte counters for all RSVP-TE LSPs and all RSVP-TE protocol counters for all MPLS interfaces.
lsp all | Clears all packet and byte counters for all RSVP-TE LSPs. |
vlan_name | Clears all RSVP-TE protocol counters for the MPLS interface on the specified VLAN. |
vlan all | Clears all RSVP-TE protocol counters on all MPLS interfaces. |
By default, all RSVP-TE control protocol counters are cleared for all RSVP-TE interfaces.
This command clears all packet and byte counters for all RSVP-TE LSPs and all RSVP-TE protocol counters for all MPLS interfaces. If the lsp all keywords are specified, all packet and byte counters for all RSVP-TE LSPs are cleared. If the vlan all keywords are specified, all RSVP-TE protocol counters for all MPLS interfaces are cleared. If a VLAN name is specified, all RSVP-TE protocol counters for the MPLS interface on that VLAN are cleared.
This example clears the RSVP-TE protocol counters on VLAN 1 only:
clear counters mpls rsvp-te vlan vlan_1
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support this feature as described in the Switch Engine v33.1.1 Licensing Guide document.
